Reset servisa na Yamaha 150 four stroke
mornar22
Prispevkov: 70
Pridružen: Ne Dec 28, 2008 03:05
OdgovorNapisal/-a mornar22 » Po Jul 02, 2012 11:46
Prosim če ima kdo izkušnje kako resetirat motor da izgine lučka napaka motorja. Motor deluje v redu mogoče se je lučka pojavila zaradi števila ur na servisu. Motor pa je bil letos servisiran.
lp Toni
mornarcek
Prispevkov: 84
Pridružen: Če Maj 31, 2007 15:57
Kraj: Gorenjska-Dalmacija
OdgovorNapisal/-a mornarcek » Sr Jul 04, 2012 09:47
V angleščini ampak vseeno:
Put the tachometer into its custom mode as follows: Put the engine key switch in the off position. Turn the switch to key-on power (do not start the engine). Hold down the “Mode” button for 4 seconds. This will get you into the custom mode.
Continue for Square Gauges: There are 5 choices in this mode. Maintenance is the first one. Select it by pushing the “Set” button. The maintenance hours should now be blinking. Push and hold the “Set” and “Mode” buttons simultaneously until you see the hours reset to zero (1 to 2 seconds). You have now reset the maintenance counter. Pushing the “Set” button will get you back to the normal menu.
Continue for Round Gauges: There are 3 choices in this mode. Maintenance is the first one. The maintenance hours should now be blinking. Simultaneously push down the “Set” and “Mode” buttons until you see the reset to zero (1 to 2 seconds). You have now reset the maintenance counter. Pushing the “Set” button will take you back to the normal menu.
These steps can be found on page 12 of the operational manual for either gauge. If you are missing a copy, you can download one here: http://www.yamahaoutboards.com/rigging/gauges
http://www.yamahaoutboards.com/owner-re ... aintenance
mornarcek
Prispevkov: 84
OdgovorNapisal/-a mornarcek » Sr Jul 04, 2012 09:52
mornar22
Prispevkov: 70
OdgovorNapisal/-a mornar22 » So Jul 07, 2012 08:03
Hvala za pomoč sem rešil stvar.
lp Toni
