Kateri motorček priporočate?
maestro9
Prispevkov: 43
Pridružen: Po Jul 12, 2010 11:57
OdgovorNapisal/-a maestro9 » To Nov 16, 2010 15:23
obračam se na bolj izkušene ribiče, da svetujete novincu.
Želel bi nabaviti motorček za vleko vabe za plovilom na morju. Ali mi lahko svetujete med slednjimi:
D3JP4 4BB
Bearing : 4 pcs ball bearings
Line Rating (1bs/yds) : 15/450, 20/360, 25/320
Line Capacity (mm/M) : 0.40/410, 0.45/330, 0.50/290
Gear Ratio : 4.2:1
Reel Weight : 472g
Size(mm) : 77 x 93 x 77
# Forged Aluminum Alloy Spool
# Line Out Alarm
CTWT20AL 3BB
Bearing : 3 pcs ball bearings
Line Capacity (mm/M) : 0.45/300
Gear Ratio : 3.8:1
Reel Weight : 490g
Size(mm) : 77 x 77 x 130
* Aluminum Spool
* Aluminum Frame Processed with the Precise CNC Machinery Provided Strength and Rigidity
* Multi Stop, Anti-reverse
* Star Drag Lever with Click
* Single Screw Lock Frame & Handle Size Cover, easy to operate
* Aluminum Line Guide
* Specialized for Salt Water and Surf Fishing
JD600 4BB
Gear Ratio : 4.2:1
Reel Weight : 505g
Size(mm) : 90 x 77 x 77
# Aluminum Spool
# Aluminum Frame Processed with the Precise CNC Machinery Provided Strength and Rigidity
# Multi Stop, Anti-reverse
# Star Drag Lever with Click
# Single Screw Lock Frame & Handle Size Cover, easy to operate
# Line Out Alarm
# Aluminum Line Guide
# Specialized for Salt Water and Surf Fishing
D6JN4 4BB
Line Rating (1bs/yds) : 20/230
Line Capacity (mm/M) : 0.50/300
Gear Ratio : 3.8:1
Reel Weight : 512g
Size(mm) : 75 x 92 x 75
# Aluminum Spool
# Line Out Alarm
in še zadnje:
ALC3000 3BB
Bearing : 3 pcs Precise Ball Bearings
Line Rating (1bs/yds) : 18/460, 20/350, 25/275
Line Capacite(mm/M): 0.4/420, 0.45/300, 0.5/250
Gear Ratio : 3.8:1
Reel Weight : 564g
Size(mm) : 95 x 74 x 107
* Forged Aluminum Alloy Spool
* Star Drag Lever with Clicker
* Specialized for Salt Water & Surf Fishing
* Line Counter and Rod Holder Included
Cene so zelo podobne, zanima me kateri od nastetih je najbolj uporaben.
Hvala!!
ludwe
Prispevkov: 202
Kraj: Cerknica
Re: Kateri motorček priporočate?
OdgovorNapisal/-a ludwe » To Nov 16, 2010 15:37
maestro9 napisal/-a:Pozdravljeni,
D3JP4 4BB
Gear Ratio : 4.2:1
Reel Weight : 472g
# Line Out Alarm
CTWT20AL 3BB
Gear Ratio : 3.8:1
Reel Weight : 490g
* Aluminum Spool
JD600 4BB
Gear Ratio : 4.2:1
Reel Weight : 505g
# Aluminum Spool
# Line Out Alarm
D6JN4 4BB
Gear Ratio : 3.8:1
Reel Weight : 512g
# Aluminum Spool
# Line Out Alarm
in še zadnje:
ALC3000 3BB
Gear Ratio : 3.8:1
Reel Weight : 564g
Hvala!!
Tole pa še mene zanima.A bi napisal še ceno?
Prispevkov: 4832
OdgovorNapisal/-a kocka » To Nov 16, 2010 15:40
Več ležajev boljša naj bi bila, mislim pa, če kontaktiraš Tuno bo najbolj sigurno.
EL CAPITANO
Prispevkov: 860
OdgovorNapisal/-a EL CAPITANO » To Nov 16, 2010 15:41
Pozdravljen,
nobena od rol ,ki si jih prilimal po mojih iskušnjah ni dobra. Vse imajo vodilo za navijanje laksa kar pa ni dobro( hitro odvijanje jim dela velike težave)! Sam uporabljam TLD role za lahko panulo.
FISHING & SAILING IS LIFE
Tuna
Prispevkov: 147
Pridružen: Sr Okt 01, 2008 22:03
Kraj: Maribor-Murter
OdgovorNapisal/-a Tuna » To Nov 16, 2010 16:13
Pravilen odgovor za mene je "nobeno od naštetih".
Vse role so najnižjega cenovnega razreda, gre za "star drag" zavore, ki se jih ne da natančno nastaviti. Rola bo zdržala leto-dve, največ tri, ves čas se boš zafrkaval z zavorami. Proizvajalec je tudi no-name.
Vodilo me niti toliko ne moti, za začetnika ima svoje prednosti.
Za ceno 150 EUR dobiš danes Shimano TLD 25, ki je grafitna, ne oksidira, enako dobra bo tudi čez 10 let, brez vzdrževanja in brez spiranja. Zavore so lever drag, kvalitetne. Prektično je neuničljiva (skuri jo lahko samo stokilska tuna).
Ne kupuj poceni stvari, ker so na koncu dražje.
maestro9
Prispevkov: 43
OdgovorNapisal/-a maestro9 » To Nov 16, 2010 16:20
ludwe napisal/-a:Tole pa še mene zanima.A bi napisal še ceno?
Cene sem na grobo preracunal iz $, tako da +-kak euro :)
D3JP4 4BB - 34€
http://cgi.ebay.com/D3JP4-4BB-Baitcasti ... 2a0b5e9b64
CTWT20AL 3BB - 33 €
http://cgi.ebay.com/CTWT20AL-3BB-Bearin ... 2a0b5e93a8
JD600 4BB - 30 €
http://cgi.ebay.com/JD600-4BB-Baitcasti ... 2a0b5e9b6b
D6JN4 4BB - 31 €
http://cgi.ebay.com/D6JN4-4BB-Baitcasti ... 27b6061310
ALC3000 3BB - 41,03 €
http://viewitem.eim.ebay.eu/ALC300_3BB_ ... 41940/item
maestro9
Prispevkov: 43
OdgovorNapisal/-a maestro9 » To Nov 16, 2010 16:23
Tuna napisal/-a:Pravilen odgovor za mene je "nobeno od naštetih".
aha :)
no, ce tako pravi strokovnjak, potem ni dileme :))
morda bom potem raje kupil rabljeno pa boljso verzijo in TLD (kaj tocno je TLD? to je le pri Shimano?).
Tuna, kako pa je kaj s Shimano TLD 15, TLD 20? V cem se razlikujejo?
Hvala ti!!
EL CAPITANO
Prispevkov: 860
OdgovorNapisal/-a EL CAPITANO » Sr Nov 17, 2010 10:52
Nobene TLD role nebi kupil če bi imele vodilo! Imel sem rolo z vodilom(ped 25leti) samo do prvega prijema :evil:
dole
Prispevkov: 376
OdgovorNapisal/-a dole » Sr Nov 17, 2010 14:58
a je problem vodilo stran odmontirat ! (mojo sem odmontiral po enem letu ko se mi je 100x zafuzlal, ne vem zakaj vodilo sploh montiratjo - zaradi izgleda najbrš.
če si začetnik bi bil kakršen koli navaden motorček tudi dober za vleko preizkušeno od ribiča, kateri sploh noče na rolo loviti, sam lovim z boljšo rolo in to je to, ker ni za pričakovat, da bom ujel kaj 10 kilskega ali pač
drugače pa se strinjam s tuno
Tuna
Prispevkov: 147
OdgovorNapisal/-a Tuna » Sr Nov 17, 2010 21:21
TLD je model od Shimana. Ne vem točno kaj pomeni T, LD običajno pomeni lever drag (zavora z ročico), T pa je mogoče za trotlziher :wink: :lol:
Joško
Prispevkov: 1774
OdgovorNapisal/-a Joško » Če Nov 18, 2010 00:07
El Capitano, kandidat in kandidatka čakata na prve šolske ure. Časa ni prav več veliko.
Vmes bom moral še k Rabuniju (s sliko) :D :D
Prispevkov: 8826
OdgovorNapisal/-a admin » Če Nov 18, 2010 10:12
Čaki čaki Joško, tole je pa neka VEELLIIIIKAAA odločitev!!! Se je ravnokar začela pisat zgodovina še enega Morjeplovca? Upam, da res, ti želim z vsem srcem! :D
Joško
Prispevkov: 1774
OdgovorNapisal/-a Joško » Če Nov 18, 2010 10:50
admin napisal/-a:Čaki čaki Joško, tole je pa neka VEELLIIIIKAAA odločitev!!! Se je ravnokar začela pisat zgodovina še enega Morjeplovca? Upam, da res, ti želim z vsem srcem! :D
V tistem trenutku, ko sem dobil mail. Vse ostalo - s kom, kdaj, kam, ... še pride. Kot sam veš, so za to potrebne priprave. Mednje sodi tudi ribolov.
Zdaj obiskujem eno 30m jadrnico, ki naj bi šla naslednji teden čez. Tip me vsak dan KURI 100/h.
Vse ob svojem času :D
navigator
Prispevkov: 445
Pridružen: To Maj 05, 2009 13:12
Kraj: LJUBLJANA
OdgovorNapisal/-a navigator » Če Nov 18, 2010 13:21
Tegale pa skor nisem mogel spregledat..to mi deli Joško...
MORJE, ŠIROKA CESTA..
dole
Prispevkov: 376
OdgovorNapisal/-a dole » Če Nov 18, 2010 14:27
Joško res ti je samo še ribiška palca mankala
