Raymarine C80 in radar
Prispevkov: 3267
Re: Raymarine C80 in radar
OdgovorNapisal/-a 1stofficer » Ne Jan 23, 2022 08:47
Grega295 napisal/-a:
1stofficer napisal/-a:Kje se kupuje rabljena navticna oprema? Ebay?
Jaz vse na eBay in ebay-kleinanzeigen.de. Če je kaka dražba, uporabim gixen.com, za prepošiljanje iz Nemčije v Slo pa mailboxde.com. Od aprila 21' do danes sem za barko naročil 27 raznih zadev.
Super, hvala !
Prispevkov: 5422
OdgovorNapisal/-a Nikola T. » To Maj 06, 2025 08:19
Večkrat sem na ZS prejel podobna vprašanja zato sem odgovor prestavil tudi v forum.
vprašanje:
Pozdravljen
Imam raymarine navigacijo (C series)...imam gor vse (globino, hitrost...)
Opazil sem da mi na karti ne izpisuje imen krajev...mapa je, navigacija deluje, pozicija deluje, vendar na karti ni nobenih imen krajev...
Je to povezano samo z kako nastavitvijo ali karta na kartici ni ustrezna ?
odgovor:
Ko je na zaslonu ploter izberi, PRESENTATION > DECLUTER > postavi na "OFF"
Iz navodil "C-Series_User_Reference_81221-5-EN.pdf"... stran 89:
Showing or hiding cartographic features
If there are a large number of cartographic objects in a particular area, you can reduce
the amount of detail by de-cluttering the chart display. Turning declutter on hides the
following cartographic objects:
• Text.
• Chart boundaries.
• Spot soundings.
• Depth contours.
• Light sectors.
• Caution & routing data.
• Land and marine features.
• Business services (if available on your cartography)
To declutter your chart:
If the declutter option is applied to a chart window that is set to SYSTEM view, the
declutter will be applied to all other system view chart windows. If decluttering does
not hide/show the particular features of your choice, they can be turned on/off
individually via the Cartography Setup menu (see page 93).
Na prikaz detaljev vpliva tudi nastavitev v Cartography Setup.
Izberi MENU > Cartography Setup > Postavi CHART DISPLAY na DETAILED ostalo vse na ON.
LP Iztok
